Results 1 to 4 of 4
Thread: 4age ecu wiring
    Default 4age ecu wiring
    hey guys searched this but no love. so i was wondering on the 14 pin plug what wires are used and wat can be chopped off and forgotten about. i know that plug has the main power to the ecu but i have no idea where to wire it and everything else. any help would be great
    also my loom was custom made so there is no plug for the little black box "circuit open" ,part numbers 85910 - 30050 061000 - 0350. will my 4age run safely without this?
    going into an ae86
    thanks in advance
    sab
    what? Automotive Encyclopaedia EVOSTi's Avatar
    Default Re: 4age ecu wiring
    get the pinouts from clug4ag and you'll be sweet.
    Here
    http://www.club4ag.com/technical_mai...tions and Data
    You can run without the circuit open relay but you wont have a fuel cut switch for when you have an accident which isn't recommended.
    If you dont have the plug you can just use electrical terminals into the relay itself
    you don't need a circuit opening realy to safely run a fuel pump.
    altt the opening relay is is two relays that turn the fuel pump on while the engine is cranking and while the engine is running. you can just switch the fuel pump from the "engine is running" signal, mine is setup like this with no problems at all.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
  1. 4age 86kw/100kw ecu?
    By trd-st162 in forum Tech and Conversions
    Last Post: 18-03-2006, 12:13 AM
  2. Best 4age ecu???
    By cerby in forum Tech and Conversions
    Last Post: 20-01-2006, 03:46 PM
