Page 1 of 5 123 ... LastLast
Results 1 to 15 of 63
Thread: 1 JZ-GTE vvti into Hilux
    Lexus wiring junky Grease Monkey Demon's Avatar
    Oct 2009
    South Africa
    Default 1 JZ-GTE vvti into Hilux
    Started the mod on my Hilux last Sunday.
    Oct 2009
    South Africa
    Default Re: 1 JZ-GTE vvti into Hilux
    Hilux 2004
    Oct 2009
    South Africa
    Oct 2009
    South Africa
    Great so got on to photo bucket and got the pics sorted so I can start posting.
    So im dropping a 1jzvvti into my Hilux Raider and it started about a month ago. Would be great to get your guys input on this. You guys may pick up sumthing that could be a problem down the line.
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    Only thing i think may be a annoyance is the sump hitting the cross beam
    Oct 2009
    South Africa
    Got the cam covers and bits off and cleaned up.
    Oct 2009
    South Africa
    Motor is still in good nick. It's only got 106000 km on the clock. I got my hands on a jzx 100 chasser half cut from Japan which was a bit bumped infront.
    Oct 2009
    South Africa
    I got it running on the floor in December just to see if it was ok. Will have to see when its under load thou but no smoke and she purs dead still on the floor. Used the fuse box from the chasser and and thats the set running with STD ECU
    Oct 2009
    South Africa
    I pulled out the wires from the chasser and built up the harnes. Going to stick in the chassers cluster aswell
    Oct 2009
    South Africa
    Motor went it and the fit was good. Had to move the power steering sumwhat to the left, its was a bit tite on the turbo side.
    Oct 2009
    South Africa
    Managed to get a good size intercooler in the front 600 x 300
    Oct 2009
    South Africa
    Got my hands on a bosch 3 stage fan but it just could not fit. Had to get two smaller ones
    Oct 2009
    South Africa
    Made up all the templates from hard board and the guys are busy lazer cutting it for me.
    Theres the full kit for the 1 j to Hilux
    Oct 2009
    South Africa
    Going to run it with a dry sump. Surge tank is going to be about 7 liters
    Oct 2009
    South Africa
    Just need the steel back and then I can tig the oil pick up pipe to the flang
  1. 1JZ vvti mod to Hilux raider 2x4
    By Demon in forum Tech and Conversions
    Last Post: 09-02-2010, 03:29 PM
  2. 1JZ VVTI / Non VVTI Question
    Last Post: 24-06-2008, 11:15 AM
  3. Hilux - BA Rotors - Nissan GT Calipers
    By infotechplus in forum Engine & Driveline Conversions
    Last Post: 20-02-2008, 07:27 PM
