Results 1 to 5 of 5
Thread: advice on fitting barrel intercoolers
    Low rep 1st year Apprentice
    Feb 2010
    western australia
    Default advice on fitting barrel intercoolers
    Has anyone fitted a barrel intercooler to a mk1 mr2 ?
    I am worried about air trapped in system just like the problems with the engine cooling system.Any hints and tips on bleeding it efficently ?
    Default Re: advice on fitting barrel intercoolers
    small header tank at the highest point. Push air out of the system using a garden hose, you don't need much glycol as it's not likely to boil, just a bit to prevent rust. Glycol actually reduces the heat capacity of water. My experience is a water/air IC on a 5cyl Audi, using a a/c core as a radiator and a RS liberty coolant pump. Hope this helps!
    Feb 2010
    western australia
    whats the best place and flow direction for pump?
    vic
    heat rises, so have the pump sucking from the bottom of the i/c radiator
    Feb 2010
    western australia
    is it ok to mount it in the engine bay near the intercooler barrel
  1. 1NZ-FE ECU & Ignition barrel problem
    By progkamol in forum Tech and Conversions
    Last Post: 20-03-2009, 12:24 PM
  2. engine builders advice wanted
    By Dimitri in forum Tech and Conversions
    Last Post: 19-06-2007, 12:41 AM
  3. AN fitting issues
    Last Post: 03-04-2007, 08:11 PM
  4. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
