i think, and correct me if im wrong, but stark is running this setup on his TA22.. hes also distributing MegaSquirt EFI in oz.. you might want to send him a PM and see if he can help you with it in some way..
Anyone running one on a 3tgteu? Just finishing the build of mine after 3 years just wondering if anyone has some base maps to get me running. Also I am using the extra spark so if anyone has applicable maps for spark I am keen also
Thanks
JZZ20 1988 Soarer GT Twin Turbo 1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
Hi 3jcelica,
I'm also in the process of rebuilding + squirting my old 3T-GTE, & would also be interested in finding someone else who has done it.
I've done a few MegaSquirt installs on various rotaries, but never a 3T-GTE.
The only contact I have who I know who's done this is Mikko Kaariainen in Finland, however his is setup as fuel only & is a MS-1. I can PM you his e-mail address if you like.
I've built a MS-2 v3 board & am looking to also control ignition, however, I've been too busy with other projects, so it is on hold for now.
While I'd still be interested to share info with you, I'm also not sure if once I've tuned my map if it will work for you, given the upgraded turbo running 1.4bar / oversize bore / custom manifolds, etc..
What sort of setup are you running? MS-1? Is it a standard or modified engine? Are you looking to replace the distributor?
I'm keen to hear how you go.
- 3T-GTE
3T-GTE,
can you share your fuel and ignition? i have one new MS2 Ver3 too but going no where on this setting..
guys/girls have you tried using the VE estimator thingy? i think it was Perry or Erics little program, to get you started with a base map.
have you got all the settings done and lookign just for VE/spark? or you need all settings?
is it the table generator inside Megatune?
Don't mean to hijack..but how much do one of these fetch, and where can you purchase from? Any info on them around?
Kind Regards,
Kurt.
1998 ER34 ニッサン スカイラインGT- T
it is? i can't find it in 2.25.... back in the old days it was standaloneOriginally Posted by CHB
jetspeed.
www.msefi.com
start reading
diyautotune.com sell them reasonably priced..
as for tables.. start with something like 20VE for cruise/decel (40-60kpa?) sloping steadily up to 95-100VE at 100kpa.... and then linear above 1atm.. is 200kpa = 200VE.. lower rpm, where you are offcam and idle etc will have lower VE of course... once you start playing you will see what happens wuickly (ie start with no load etc)
for timing... it varies so much but... sayy...20deg at 100kpa and 30deg at cruise kpa?? and boost? retard x degrees per boost... start very conservative and go from there...
stu- v2.25 of megatune has table generator built in. When you open the fuel or spark map editor windows (under the fuel or spark menus), it's available to you in one the windows menus..
the maps it generates do need reasonably truthful estimates of:
-redline RPM & MAP
-idle RPM
-max torque RPM & MAP
-max power RPM and MAP
and it can generate maps that make you run very, very rich.
As for timing maps, there's a very useful thread (with many attachments) here that you should spend some reading,
holy moly! i didn't notice the tools on those pages
i did notice the "autotune" tho
i have so much to read up on when i get back
thanks for the links!
CHB, I don't have any maps yet, as I'm currently rebuilding the engine. After the last race outing at Mallala it doesn't quite have the same "punch" as it used to.
I'd go with the table generator to set up your base map & then go for some very conservative + safe settings, then start tuning from there.
My engine is also probably going to be quite different to your's with oversized pistons, high-flowed CT-26, 550cc injectors, etc...
I'm also looking to potentially stroke it - if I can offset grind the crank enough to fit some perfect-sized rods, so this will take it to a 1973cc engine which I'm sure would make the map different to the standard 1770cc.
How are you planning to tune once you have got a base map? Do you have / or can borrow a wideband O2 setup?
Stewart, when are you planning to be back? I'm planning to get together with a few fellow MSers here in Vic, but also keen to catch up with a few people interstate on one of my work trips.
3T-GTE
yeap i plan to get a Wideband O2 from DIYAUTOTUNE. quiet regret didn't get it at once when i purchased my Ms from them..do you mind to tell me what conrod r u going to use in order to increase the stroke?
a while... minimum 1 year... maximum? no ideaOriginally Posted by 3T-GTE
i should be coming back about this time next year for at least a holiday...
one thing is going on now.. wanna ask you guys's opinion
eventually i plan to run ignition control from MS via distributor VR sensor.. but after reading some articles, i plan to use back my OEM ignition system (toyota ignitor and coil).
can i share the signals from the VR sensor between MS and the ignitor? can i just splice the VR sensor wires (red and white), and run 2 wires to MS and another 2 to the OEM ignitor? in this way i can run fuel control from MS and OEM ignition system.
I've started building my MS-2 with V-3.0pcb, and will hopefully have it running on the 18R-GE in a couple of months. It's a similar engine to the 3T-GTE, if you remove the whole twin-spark shite from the 3T....
Just gotta pick up the nice Vishay resistors from S(L)oanar and one or two other bits, and it's complete
Once i've played more, i'll add my feedback here
