Results 1 to 14 of 14
Thread: Gasket Sealant on Carburetor Mount ?
    Selangor
    Default Gasket Sealant on Carburetor Mount ?
    Do any of those Permatex or so-called RTV
    gasket sealants need to be used when mounting
    a carburetor on its pad on the intake manifold ?
    My usual mechanic says no, the pad is a kind
    of fiber material and is not supposed to have
    any sealant coated on it. He said the pad will
    flex itself in place when the nuts are tightened.
    However, I think my 4K's carb might have a
    very small vacuum leak along its mount. The
    engine idles normally when cold, but goes very
    rough when it heats up. It doesn't appear to
    be vapour lock.
    Default Re: Gasket Sealant on Carburetor Mount ?
    silicon gasket sealant (RTV etc) will absorb petrol and go all mushy.
    you can use it if needed (to seal slight leak, but usually is not necessary.
    there are non-silicon sealants you can use (STAG jointing compound comes to mind) which aren't affected as much be petrol...
    if it idles normally when cold, but not when hot, the idle mixture might be too rich.
    and never EVER use silicon sealants to seal gaskets IN a carby. it will absorb petrol and squeeze out of the joints and do nasty things like get stick in jets of fuel passages.. all bad...
    Selangor
    Thanks for the help.
    One mechanic I asked also told me the same risks
    with using silicon sealant in a carburetor gasket.
    Apparently the carb on the 4K does not have any gasket
    - there is only a black-colored fiber-type mounting plate in
    between it and the intake manifold. The mechanic said
    he could try fabricating a paper gasket, without any
    sealant, and slide it in between the carb and the mounting
    plate to try to seal any leaks.
    I did write to Larry Carley, a very experienced auto
    diagnostics expert at AA1car.com, and he said that my
    problem sounds like my air/fuel mixture is suddenly going
    lean when the engine reaches a certain temperature.
    This could well be a bad intake manifold which seals
    when cold but leaks when the engine gets hot.
    He suggested that I use a vacuum gauge to note the
    reading when the engine is started, and see if it drops
    as it gets hot, which would mean a vacuum leak someplace.
    I'm wondering where to take the vacuum from though.
    I am using a 3K carb on my engine currently, and the
    only vacuum outlet is to the distributor advance, which
    has no vacuum at idle ! The stock 4K carb had another
    vacuum outlet to the hot idle compensator, taken from
    below the throttle plate, which would have been ideal.
    there is a paper gasket between the top and bottom half of the K series carburettor.
    there should be a gasket between the base of the carby and the manifold also.
    use some... 0.5?0.8?mm thick gasket paper to make this.. you MUST have one there.
    on the manifold, on one of the runners, there is a little screw in plug. this is where you can get the vacuum signal..
    OR, the base plate under the carby.. which has a tube that connects to the rocker cover, this can also be used as a vacuum source.
    what about that aviation gasket sealer stuff that doesnt dry, isnt that petrol safe?
    im gonna go look in the shed, we have a gasket former thats petrol safe...
    hylomar? hmm. maybe.. makes it a bitch to get things off tho great for headgaskets tho!
    S.A
    like old corrals says the should be a gasket either side of that black fiber plate!!!!!!!!!!
    all the plates i have seen are that hard there is NO WAY it will crush enough to get a good seal.
    i would use permatexn on either side of each of them gaskets
    the one i use is loctite no.3
    non hardening sealant
    aviation gasket sealant
    "engine assembly compound and pipe fitting cement - does not harden. resistant to petrol, oil, water, antifreeze solutions and most liquids and gases"
    me thinks this would do the trick, and if i remember its what i used, i use it on most gaskets...
    Selangor
    Thanks a lot, OldCorollas, 30PSI 4AGTE and Love KE70.
    Wow, I don't remember seeing any gasket paper at all
    on top of black fiber mounting plate when the previous
    mechanic took out the old stock 4K carb - it just came off
    clean - no old gasket paper stuck there, no sealant,
    nothing, just a nice clean black plate at the bottom !
    I don't think I saw any gasket between the plate
    and the manifold as well. I wonder if it was assembled
    that way. And he installed the new carb right on the plate
    without any gasket in between either - just screwed on
    the four nuts tight and that was it !
    I'm going to get the new mechanic to put at least 0.8 mm
    thick gasket paper on either side of the mounting plate
    soon as I can. I'm also going to ask him to replace the
    intake manifold gasket to the cylinder head.
    I'll see if I can find some Loctite Aviation Gasket Sealant.
    Love Ke70, is this the one you have ? Looks like
    Loctite No. 30516/7. Some stores also list it as Loctite
    No. 37558/9. It looks quite heavy duty indeed.
    http://www.dragosupply.com/drago/ser...log/group.jsp/
    http://www.hrpworld.com/index.cfm?fo...action=product
    never used it but looks like it should work... not too expensive either....
    i often used red RTV on the "manifold to head" gaskets to make them easier to take off, but if you don't plan to take the manifoldoff often, this sticky aviation stuff will work
    Selangor
    Apparently the previous mechanic never applied
    any RTV or other type of sealant either when he
    replaced my intake/exhaust manifold-to-head gasket.
    Just screwed on the nuts . Not sure if he
    did it in the correct sequence either.
    it is usual not to use sealant on the intake/exhaust gaskets.. i do because i remove them often... and i also have to make my own so they will fit.... i don't think it is necessary for those ones, but i would use something on the base of the carby... at LEAST paper gasket whether you use goo or not... should be ok...
    not that same bottle, but it looks like the same stuff
    on my bottle, its only 50ml it has blue writing, white bottle, red lid. id say its the one. the part number on this one is 3J
  1. Changing 1GGTE Head Gasket
    Last Post: 31-03-2006, 09:26 AM
  2. Rocker Cover Gasket Sealant
    Last Post: 19-03-2006, 07:42 PM
  3. Gasket goo on exhaust manifolds
    By Chubs in forum Tech and Conversions
    Last Post: 14-11-2005, 02:01 PM
