Results 16 to 25 of 25
Thread: throttle body injection.. which cars / motors?
    Chiba
    Default Re: throttle body injection.. which cars / motors?
    Quote Originally Posted by Supra967 View Post
    3.9L Falcon back in the XD/E (i think, one of the square ones after XC) range. Engines were 150hp or less, so TB and injector might be about the right size. Should be able to pick up from any wrecking yard.
    X series Falcons all had multipoint injection (Bosch LE Jetronic for the XE, Bosch Motronic for the XF). The XD didn't have an EFI option. Just a double barrel Weber carby.
    The EA/EB Falcons had singlepoint injection on the lower spec models (higher models used the multipoint Motronic system similar to the XF). It was based on the Bosch Motronic system and used two injectors in the throttle body.
    Jul 2009
    Quote Originally Posted by TERRA Operative View Post
    Ah, cool. I remember seeing it on a car at auctions, been a while though.
    Turbo Cordia had TBI - i possibly have one floating around in the container somewhere
    I'm assuming you're working with the mid 80s carbied turbo charade in a blow through setup?
    Have you investigated whether the inlet manifold off the next model Charade fits? These had 3 injector bosses built into the manifold for multi point injection and are a much better thing.
    Junior Member Automotive Encyclopaedia eeeyan's Avatar
    Sep 2009
    or for a blow through carby setup from a slightly bigger motor the ET pulsar 1.5 turbo was blow thru wasnt it?
    Wish I had a F#%ken awesome toyota.. saving for the goodness now.... stay tuned....
    No, Pulsar ET/Exa turbo were multi point injection. First factory turbo cars in Oz to be so.
    earlier subarus do tbi, huge injectors too/ we had a liberty wagon in queenstown that we hired for the snowfields that was like this
    I reckon I've seen TBI on the bubble shaped Barina as well.
    Quote Originally Posted by SillyCarS View Post
    You mean a Legacy wagon in Queenstown, NZ, as opposed to Queenstown, Tasmania, because no Oz delivered Subaru has ever had SPFI, they've always been MPFI.
    sticker makerer Grease Monkey
    thanks guys ive got a tbi setup on the way from madmont, if its not suitable ive got enough to go on now.. cheers
  1. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 09:15 PM
  2. Throttle body boring in Brisbane?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 08-02-2009, 10:32 AM
  3. aftermarket throttle body - for 1UZ - what options are there?
    By 1jz180 in forum Tech and Conversions
    Last Post: 06-02-2009, 08:12 PM
