Hey guys just wondering if someone can help me to wire up the overdrive on my conversion. I've got an 89 mz20 with a jza70 1j in it, I'm driving around with 3 gears at the moment, I think the o/d wire from the jza70 loom is grey or pink-green but I don't know where to connect it to on the mz loom, any help would be muchly appreciated
Cheers Josh
On the 1jz vvti the ECT is running from your ECU. Check your pinouts for the ECU and it should be on there as ECT, That wire needs IG+ put to it thru your ECT power switch, that will kick in your solinoid in in the gearbox. The OD2 will run from your ECU to your cluster which is your ECT light. It should flash untill you start the motor
