Results 31 to 45 of 61
Thread: Plenum design idea
    Default Re: Plenum design idea
    Quote Originally Posted by TurboRA28 View Post
    Justin, how thick would the baseplate need to be for the router idea to work ya reckon?
    It should work on any thickness (within reason) and you can just clamp some MDF to the plate if needs be.
    Regardless i'd try and use a sturdy 10 or 12mm plate anyways.
    I'm aiming to go to Pick N Payless this weekend as I need some stuff.
    I'll have a scout around, but I doubt there'll be anything there that new.
    I do know of another wrecker at Yennora that usually does newer stuff, and I'm also aiming to go there on the weekend.
    BTW, not quite sure how this would work, but have you thought about the reverse idea to an exhaust manifold? ie use 90 degree bend pipe the same size as the holes & somehow merge them together into a forward facing manifold.
    bit out of left field.
    What's the clearance issue for you? I thought the manifold followed the shape of the head fairly well due to the tilt on the engine.
    with the thicker sheet u'll get away with more heat/bending when you weld it to
    I see invisible people Backyard Mechanic WHITCHY's Avatar
    New South Wales
    Nice quiet day for me, haven't managed to find dick about acura intake onto 1mz?
    Found some stuff at WTF auto... still looks too high, and f**k knows how they get the mani on and off?
    http://www.wtfauto.com.au/news.htm - scroll down to 1/9/2007
    Quote Originally Posted by tomvale13
    I always feared Harold the Sexual Abstinence Girraffe or whatever the fuck that thing was in primary school - any Large African animal with that much pent up sexual frustration is the last thing you wanna confine to a small darkened caravan full of kids.
    Had a swing by pick-a-part this arvo and there was 2 V6 Hondas there, but they were very different to the one pictured above. Don't think they were useable.
    Was the same as this one - http://cgi.ebay.com/ebaymotors/Intak...mZ350200373491
    ([][][]II--LT--II[][][])
    Chief Mentallurkist Grease Monkey
    I was gonna say to have a look at Skids thread, but you already have...
    skiddz's V6 shenanigans - 3vz-fe meets ta22
    Maybe give him a kick and see if anythings happened recently
    Hack
    "Your car is a little metal death box, and whatever joy you may find on the road is strictly a function of your insane denial of that truth." My denial is indeed, INSANE
    For all other times the Celsior of daily duties awaits!
    sorta related.. Cosworth manifold for V6 with integrated stacks..
    http://blogs.cobbtuning.com/christia...manifold-2.jpg
  8. #38
    OC,
    That picture name reference's a VQ35 which is a Nissan with a V6 engine.
    However a quick google image search turns up a world full of options for these engines.
    I wonder if the Nissan manifold is adaptable to the MZ engine?
    Turbo....
    Canberra Celica Group
  9. #39
    Apologies OC Cosworth do a manifold for the VG...
  10. #40
    i know it is for nissan, but if you have limited height, but can put in a 90deg turn for the bellmouths, then you can spread the plenum sideways (in two halves) like the cosworth one = easier to bolt on maybe, and easier to get volume perhaps, with no trumpet/plenum clearance hassles...
  11. #41
    How hard would it be to fit twin throttle bodies to that Honda manifold and plate up the "back"?
  12. #42
    Im actually thinking oldcorollas may be on the money.. nissan style, 90 deg turn on runners and 2x plenums on each side..
    means more clearance as the plenums can sit over the valve covers.. can get to bolts easy..
    so this is going to mean long runners.. as the runners are going to be quite long, does this mean smaller plenum?
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  13. #43
    it also means more low down driveability over top end zing
    Never late in an x8
  14. #44
    what is the common method to join the two throttle bodies together? 2x cables?
  15. #45
    Penrith BC
    linkage shafts
    ../delete/ban
    tech moderator
  1. Intake plenum theory
    By andrew_mx83 in forum Tech and Conversions
    Last Post: 22-12-2009, 06:50 AM
  2. Performance 2T-ZE design
    By Radar in forum Tech and Conversions
    Last Post: 14-12-2009, 01:27 PM
  3. Ultra Small & light weight RWD idea.
    By Johnzoku in forum Tech and Conversions
    Last Post: 13-03-2008, 08:54 AM
  4. Stainless piping diameter question eg plenum
    By Mr Multivalve in forum Tech and Conversions
    Last Post: 27-04-2006, 09:31 PM
