Results 1 to 6 of 6
Thread: jza70/ma70 R154 front tailshaft length
    Default jza70/ma70 R154 front tailshaft length
    Does anyone have the length of the front section of an x70 front tailshaft section for the R154?
    Thanks,
    Jason
    Mobile Backyard Mechanic PeteH's Avatar
    May 2007
    Default Re: jza70/ma70 R154 front tailshaft length
    The front section measures roughly 475mm from the centre of the bearing cap to the front of the flange face.
    Pete
    Junior Member Backyard Mechanic xistant's Avatar
    Mar 2009
    victoria
    front section without attachments (ie front yoke or center spline) is 304mm just the metal middle section
    13.39sec @ 110.86mph.
    265rwkw Supra (and climbing)
    when are people going to admit to the fact that torsens are totally gay for serious trackwork?
    Excellent, thanks guys.
    Pete, when you say the center of the bearing cap, which part exactly are you talking about? The center of the uni rose-joint hole?
    Jason
    May 2007
    Jason, yep measured from the centre of the uni joint hole. To be precise i measured it from the centre of the uni joint hole on the slip joint.
    Hope that helps,
    Pete
    Perfect, thanks again
  1. short stroke shock absorbers for AE86
    By roadsailing in forum Tech and Conversions
    Last Post: 17-01-2007, 04:11 PM
  2. length of SW20 front suspension control arm?
    Last Post: 19-08-2006, 04:49 PM
  3. 1JZ-GTE Dipstick Length
    By 82MKII in forum Tech and Conversions
    Last Post: 23-05-2006, 03:28 PM
