use a series 2 crossmember and jzx81 alloy engine brackets, then it bolts straight in. You need to bend the oil feed pipe to the turbo very slightly to clear the jzx81 bracket, but it works fine.
Wiring is the same as any other conversion, quite involved but the jzx100 A/T ecu will work with an R154 just fine.
