Results 1 to 3 of 3
Thread: What W5X is this box?
    Junior Member Grease Monkey omy's Avatar
    NT
    Default What W5X is this box?
    Speedo did not work when I bought the car, just had a look that the speedo gear drive and it seems that they don't touch at all. The gear drive is marked 10/32 but seems to small a OD to even touch the drive gear on the output sharft. Does ant know what speedo gear would work, and also the type of W5X it is?
    Default Re: What W5X is this box?
    http://www.toymods.net/forums/showthread.php?t=5487
    We can't tell you what gearbox it is from the gears, work it out via RPM at a set speed; for example
    2nd gear @ 60kph
    3rd gear @ 60kph
    4th gear @ 60kph
    5th gear @ 60kph
    Then you can work out the ratios of the gears in relation to each other. A W55 will be most easily identified by the 1st->2nd->3rd->4th gear ratios. A W57 and W58 will be discovered by 4th->5th gear ratios.
    NT
    Cheers mate.
