Results 1 to 14 of 14
Thread: Modifying a 2SC
    Apr 2007
    Default Modifying a 2SC
    Hi guys.
    I have an 84 Celica with a 2SC...not the most desirable engine I know...but its all I have at present.
    Any simple ways of increasing engine power ?
    Am having a larger exhaust fitted soon.
    Any help appreciated.
    Rob.
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    Default Re: Modifying a 2SC
    a 3sge in place will do the job
    just allow it the breath in and out and you should be right, maybe run a better fuel with some better sparkplugs and fresh leads should do the job also
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    Apr 2007
    Thanks....I have not had a good look yet but it seems to have twin exhaust headers...so a bigger bore exhaust should help.
    Can I replace the air cleaner and if it has an ecu can that be modified ?
    Rob.
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Bigger exhaust will help a lot....yes and change the standard air intake setup for sure maybe with a carby change.
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    but where can you find extractors for these?
    Forum Member 1st year Apprentice raffy73's Avatar
    May 2009
    Quote Originally Posted by rallyra28 View Post
    Hi guys.
    Rob.
    I had the same car like yours back in 1997.
    It had a 2SC with a carby.
    I had 'Motivator' extractors (I think they are made by Lukey) and a 2" sports exhaust system with a 'hotdog' resonator fitted.
    The whole set-up cost me about $600 fitted. (Cheaper back then pre-gst days)
    I found that the engine's power output improved just a little bit but it did sound great.
    If you do get a system like this and you find it keeps making a really loud backfire everytime you back off the accelerator, you will have to remove the airpump belt to stop the backfires.
    May 2007
    tasmania
    mine has no airpump and it still back fires alot
    Apr 2009
    Maybe a nice cam as well with the exhaust will do wonders.................
    May 2007
    tasmania
    who would supply such a cam?
    mate.. there is no ecu - it's a carby engine
    a good exhaust and carby will make it sound great, but your power increases are going to be very small for the amount of money you'll be spending
    pretty much you're starting with the wrong engine. and 18R will slot in there with an RA60 xmember for more power, or you've already got some good bits to begin looking at a 3s conversion, but I guess it all depends on what you want, and how much money you feel like spending
    Sep 2009
    Rob, drop in a 1gz-fe and be truly unique.... assuming you win a lottery or two.
    Apr 2009
    Quote Originally Posted by ecko View Post
    Most performance shops may sell one, or locate one, or you can get your existing one re-ground to change the duration.
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Quote Originally Posted by AdrianS View Post
    Why would you suggest such a thing? Surely it would be cool but it is nowhere near helping his cause so why bother mentioning it?
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Sep 2009
    Quote Originally Posted by Pimpin_1JZ View Post
    Given that two other posters suggested an engine swap, when the OP is looking for a simple/cheap method of increasing engine power, I thought he'd be amused by the ultimate swap.
    More seriously, given that the car has some slight rarity (see http://www.toymods.net/forums/showthread.php?t=55193), I would keep the 2SC, with better breathing and maybe a mild cam, as others have suggested. I've seen the car; it's a good find, and worth keeping (outwardly) original.
    I'll pull my head in now.
  1. Modifying Camry Engine 1MZ-FE
    By Camry_Grande in forum Tech and Conversions
    Last Post: 20-11-2011, 01:44 AM
  2. Legalities of modifying strut tower, or strut?
    By Fattony in forum Tech and Conversions
    Last Post: 22-01-2007, 08:16 AM
  3. Modifying Dashes and custom center consols
    By frozenwarp in forum Tech and Conversions
    Last Post: 20-02-2006, 11:25 AM
  4. Modifying the Beams 3S
    By admin in forum Tech and Conversions
    Last Post: 26-12-2005, 09:57 AM
