Thanks to 1JZ-Rolla:
Coil color ID = Gray then 130 - 210 Ohms
Coil color ID = Green then 185 - 265 Ohms
Pulled from here:
http://www.autoshop101.com/forms/h23.pdf
Trying to find out what the factory range is for the resistance measured across the 4AG reluctor pick ups in the CAS.
If anyone knows that would be greatly appreciated.
I'll continue searching for it too and post here if I find it.
My KE25 thread
Pulled from here:
My KE25 thread
Used to determine if the reluctors are dead and is the cause of a trigger issue on someone elses 4A, luckily mine are still well within spec but it seems this other one is not.
It's having starting issues and intermittent trigger faults showing up on the ecu.
Looks like it's time for a new CAS in this case.
My KE25 thread
My KE25 thread
