what are the spare holes in magenta meant for?
Signiture edited..... Read the Rules
from memory they held the hand brake hub assembly on
seriously dude,magenta?
use the front two,far less work and you wont have to worry about any decrease in strength(if any really)from cutting the lug off.
not worried about any effects of removign the factory lugs (the ones i dont end up using will get gut of anyway to save weight)
mor how srtong with the other holes be - dont look like theres much meat on them - esp if i gotta open them up to 10mm
Think of it this way. If you use the 'magenta' holes, and they fail on you under hard braking on the road and you have an accident, will it have been worth it?
Get it engineered.
so what about if it fails on a race track![]()
Owner of the Big Red Whale
Originally Posted by Stomps
If it is purely a track car, then that is a different matter. That is up to whoever is running the show to make sure your car is suitable.
But if it is a street car, then it should comply with legal requirements don't you think?
And that means engineering as far as I am aware.
My 2c.
i would want to keep the caliper in the same position as factory, because i guess the suspension and brackets have been engineered around it; you are pretty much guaranteed to be free of fouling on anything.
dunno why you dont make caliper adapters up.
if you dont need them engineered then it will be even easier
MX83 2JZ-GTE!!
#YOLO.
ok - didnt realise i would have to go into so much dept to explain but i will
is a dedicated track car - wont see any street driving
deff cannont mount adapters off point A full stop..
eif the caliper mounts on original side - will be very touch and go with fouling on the camber arm bolts which isnt a bid deal as ill be upgrading those soon
can mount them on leading side no drams what so every as far as clearance goes
heres the brakes in question (324mm basically f40 calipers)
http://img704.imageshack.us/img704/6861/pc030045.jpg
if they were 332 + mm rotors id prob be able to utilise A and B
