straight argon is more expensive then mixed argon......... Id only use straight argon if it was on somthing that i wanted to show off eg a show install.
Tig can be a **** to get right if your not confident in using it. But as said it needs to be close to "medical" clean
ended up with quite a surface to be flattened.
Ceramic coat and then wrap
The manifold is constantly shedding heat, once wrapped it is no longer shedding heat....must go somewhere?
