The barrell only reads the key which then tells the body control(the factory immobiliser) Which then goes to the computer to start the car it's a pain but you will probably need to get the 5 pin barrell and then have to get a scanner to reprogram the whole system!! Which i think only toyota has the program to do it.
Otherwise if you can work out the wiring to bypass the key reader(barrell) by bridging the wires this should work aslong as all the componets came from the same car
The only downfall is it wont be secured by the key
