So.. once you pull the HT lead out and the engine stops... then put the lead back on, you don't have the ignition light on in the car?
Seems like the ignition has been wired active permanently.
One way to check... if you can push start the car with no key in the ignition switch, then you go a perm live ignition. Of course, with no key means the steering will be locked, so to do such a test you need to be in a safe area, and once the engine fires up, apply the brakes immediately.
seeyuzz
river
