the results will be the same if the air temperature entering both the HXs (heat exchanger) are the same regardless of connection configuration.
i had a look and its a bit complex to get accurate results from (by varying inlet temp to one HX). what i do think is that once your moving along pretty quick (say over 40) the air temp and the HX under the car will be the same as the HX at the front of the car.
i wouldnt be suprised if there is nearly no airflow through the HX under the car above 40 due to the type of flow (turbulent).
also by saying this, even if the inlet air temp to the HX under the car is quite hotter, the slow flow of air will negate any "reheating".
you think your HX under the car is good but its probably the heat capacity of the oil taking in all the heat
cp of oil is about 2000J/kg.K
to raise 7 litres of oil by 40deg is about 560kJ
to do that in 1 second you need 560kW of power
or nearly 10kW to do it in 1 minute
what im saying here is for hillclimbs and drags, most of the energy will be taken up by the fluid itself compared to heat transfer through that HX under your car
