What boost levels are you running and do you plan to go any higher?
I ran a 2100lb Luk full face organic clutch behind mine, but I was only running 10psi.
That had no issues.
Hoping someone can share some advice on what clutch to run, I have a 7mgte mounted up to the standard MA61 w58 5 speed and flywheel, it's currently running an Exedy Sports Tuff that has only done about 1000km, problem is that it slips as it comes on boost in 3rd and 4th gear, the pedal feel is fairly light considering its a heavy duty unit and i'm not sure that it has enough clamping pressure.
I would be happy to shell out for a kickass on/off clutch but would like advice from someone who has one.
and also what would be some good brands to look at?
That had no issues.
happy to sell two clutchs that I have that were behind. 7MGTE's. One I have driven was great no slip probably only 5000km's on it. 200rwkw 7m, the second came on a 300rwkw motor that I have never driven.
I've gone auto and got no use for em.
