For anyone with an st185 or st205
My 5x114.3 conversion(mentioned in previous posts) uses
Front Rav4 drive flanges
Rear Toyota Highlander bearing and drive flange package
Front brakes are Ba falcon 329x28mm rotors with wilwood 4pots from MRP (discs need spacer/locator ring and adapters for calipers) but its there st185 kit setup for 5x114.3
Rears are going to be z34 370z 350x20mm rotors (work with factory 170mm handbrake) (discs need spacer/locator ring and adapters for calipers) and remanufactured 370z Brembo 2pot calipers from Stop tech, could also go for the z33 350z 322x22mm
You can also use Z32,R32,R33,R34 rear Rotors (290mm) with the factory handbrake with nissan 2pots adapters etc required
Apart from custom braided lines, caliper adaptors and locating/spacer rings
Parts are common and off the shelf
Pads, discs, calipers, caliper rebuild kits etc
Hope this makes sense
shell has already been seam welded
