This thread on Bimmerforums might be of interest:
http://forums.bimmerforums.com/forum....php?t=1341030
The piston sizing needs to be suitable for your vehicle (master cylinder, pedal ratio, bias, etc...)
been stumbling across some bargain brakes lately which i dont have the strength to say no to..
heres what i have
f50 brembo calipers (44/40mm)
f40 brembo calipers (44/38mm)
stoptech - st40 (40/36mm)
for those that dont know, stoptech apparently copied f40 brembo design and modify them for the better,,, claim they are significantly stiffer etc etc.. they look pretty similar however are not identical mouldings or anything
i know f50s are generally regarded as better then f40s but the only diff i know of it the leading piston being 2mm bigger....
my question is - how would the stoptech calipers rate as far as performance to the brembos with the bigger pistons... the brembos run ferrari pads while the stoptechs run a porsche pad
edit.. ps - im chasing a jza80 hats to suit 355x32mm rotors so if anyone has any hook ups that will be great
Signiture edited..... Read the Rules
If those stoptechs are 4 pistons then they are way to small for our cars.
(when looking at piston surface area)
The F40's are 8% larger than stock
F50's are 4% smaller
ST40's are 15% smaller.
I'm not sure what the acceptable limits are without affecting to much, but I'd hazard a guess that anything outside the +/- 10% range would be too far.
