Results 1 to 5 of 5
Thread: 1jz wont start :(
    Jun 2006
    Tasmania
    Default 1jz wont start :(
    Hey guys
    jzx81 with 1jz, took it for a thrash the other day drove fine, soon as i pulled up it wouldnt start
    Symptoms are, it starts and runs for about 2 seconds then turns off.
    Put the noid lights on the injectors and they pulse fine while it starts then they cut out, so yea, not getting injector pulse after a few seconds. Weird
    cant work these dam codes out lol
    Default Re: 1jz wont start :(
    Have you pulled the codes?
    Perhaps its an IGf issue?
    Wilbo's JZA80
    Wilbo's JZZ12
    Jun 2006
    Tasmania
    na haven't done, i joined the two terminals together in the diagnosis plug but it doesnt make the engine check light flash ?
    It doesn't loose spark either just injectors
    Tried bridging the fuel pump?
    I can't think of any situation where you'd loose injector pulse but retain spark.
    Except for major situations like failed ecu, failed injector(s), or loss of 12v to injector.
    Jun 2006
    Tasmania
    yea im going to double check its all then ill prob chuck another ecu in or something.
    Werid like you say, no pulse but spark
    Also how its consistent every time, starts then cuts out so its prob not the ecu
  1. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 08:13 PM
