Results 1 to 12 of 12
Thread: 3s-fe position -SOS
    May 2009
    Greece
    Question 3s-fe position -SOS
    Im not sure if i can sleep tonight,
    im making a conversion , im gona use a 3s-fe engine , i have allready connected with the
    gear box , but im not sure if i do it rigth im afraid its oblique
    take a look here ,
    http://i605.photobucket.com/albums/t...pro/engine.jpg
    i took a standar that the left bace is vertical , but...
    how can i found the rigth position ?
    its to bad if im wrong 2-3 degrees
    can any one help me please ?
    Default Re: 3s-fe position -SOS
    What is that gearbox????
    If you look at your first picture of the engine still in the car, you'll see that the top of the head that says "toyota 2000 16 valve" is almost horizontal.
    If you set up the engine tilt so that the part described above is level (or almost), you should be pretty close.
    I don't think a couple of degrees will matter too much, but if you stodd the motor up, that could cause problems with oil draining out of the head.
    You can check out his build thread here or here
    I wouldn't be worried about the angle of the motor as it is designed to be on angle. As wagonist said it looks to be about the same angle as the factory angle. Is there going to be an issue with the sump baffling due to running it in north-south instead of east-west?
    May 2009
    Greece
    Thank you very much for your replyes
    im talkking for the orange angle , the red is still easy to change
    wagonist
    The gear box is from unimog , look here for more if you want
    http://www.pirate4x4.com/forum/showthread.php?t=773430
    stidnam
    north-south * east-west , i dont know how is that
    but im gona use it , not like it was , do you think this a problem ?
    Here is a picture of the carter (how is now)
    http://i605.photobucket.com/albums/t...o/DSC00039.jpg
    here is a plan from a manual (nont know if is rigth or just a plan )
    http://i605.photobucket.com/albums/t...Screen0116.png
    and here is the oil level :/ ( i thnk it was ok when engine was on camry)
    http://i605.photobucket.com/albums/t...o/DSC00040.jpg
    If someone have 3s-fe on his car , please upload some photos
    <off topik>
    is any one know where can i find a dyno diagram for 3S-FE ( year 87-90 )
    north-south: means engine is along the vehicle, like rear wheel drive (yours)
    east-west: means engine and gearbox across the car, like the camry the engine came out of.
    Looks to me like you have got the angle pretty good.
    For pictures of the car this came out of, search for "SV-21" camry in the readers rides section. maybe some dyno graphs in there too.
    May 2009
    Greece
    ok thanks , for this info
    so im gona use north-south , an engine that was east-west
    can this come up new problems ?
    Quote Originally Posted by Toymog View Post
    In your situation, I do not think so. It depends how much room there is in your engine bay.
    For others, the air intake, distributor usually are in the way and touch the firewall.
    the North-south version of this engine has the distributor on the side of the head (or the other end), and the air intake faces the other way.
    the coolant pipes are usually in a different location, too.
    May 2006
    Hey, I'll get a picture under my camry when I find the camera! It's a 5SFE, but the orientation is exactly the same. The flat base of the sump is parallel with the ground though if that's any help for now. All the oil drains are on the intake side of the head, so It shouldn't have too many drama's.
    May 2009
    Greece
    thanks for your offer beerhead .
    Gearwhore. Backyard Mechanic
    Oct 2008
    That's right, girlfriends 5S is on the exact same lean. Last 3VZ I looked at was at a bigger angle at that.
    Look at E30 M3's - HUGE amounts of lean for a NS engine.
    May 2006
    Hey - Got you a couple of pics. Would need to get it on stands to get under the thing though...
    Camera is level with the ground on the sideways shot, so they really do lean over quite a way.
    May 2009
    Greece
  1. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 09:15 PM
  2. W58 remote style shifter position to normal rear shift swap?
    Last Post: 11-05-2009, 09:12 PM
  3. w5x shifter position change pics
    By maurice c in forum Tech and Conversions
    Last Post: 12-02-2009, 12:08 PM
  4. 2s 3s conrods
    By bmxer54 in forum Tech and Conversions
    Last Post: 30-03-2007, 08:27 PM
