Results 1 to 9 of 9
Thread: MY fuel setup
    IWRNDU Automotive Encyclopaedia DQIKST's Avatar
    Default MY fuel setup
    hey guys i have been reading through the faq
    about fuel setups and the Witzl said that i need a return line.
    i drew up a diagram of my fuel set up,
    http://img83.imageshack.us/my.php?im...upsmall1ac.png
    had the car running on the weekend and it was reving hard and fuel kept up with no problems.
    just wanted ur insight on this please
    REguards
    IBZ
    ThE wOrLd GoEs RoUnD n RoUnD nOt Up N dOwN
    Daily 76' celica 1GGTE 1125kgs 13.7@ 91mph
    NOS= ITS LIKE A HOT CHICK WITH STD's YOU WANT TO HIT IT BUT ARE SCARED OF THE CONSEQUENCES
    whats the gee-ooo with every one having chicks in there avatars
    1980RIP NATHAN BRETT DEAN2007,
    Default Re: MY fuel setup
    With a carby setup, a return does not become a huge issue as the pump will just slow they flow a little when it reaches a pressure... It's not an issue of the engine not getting enough fuel, without a return line, you have nowhere for the unused fuel to go. This being the case in a EFI setup where fuel flows thru the rail, instead of filling a bowl in the carbys.
    Do the solex you are using have a return fitting on them at all?
    CHECK IT OUT HERE
    it totally depends on the output pressure of the pump.. if the pump is self limiting to the correct pressure, a return is not needed...
    as far as i know they dont but when i asked the witzl he say you must have a in out and return. im sure i told him i had a carby set up.
    is it a problem the fact i have the pump and fuel filter in the Jack/tool compartment which means it is lower than the tank??
    REguards
    IBZ
    are you running a regulator past the carby, eg highish pressure upto and past the carby with a regulator(with manifold vacume line) after the carby adn a return line to bleed of the extra fuel/pressure?
    Junior Member Grease Monkey craigy's Avatar
    You should have ran your filter before your pump, so if there are any impurities in your fuel they wont make there way into your pump.
    Not a big issue, just thought i'd mention it.
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    It isnt to hard to change it around.
    should i have put a fuel filter in my engine bay aswell????
    Karl might have thought you were after an EFI setup, where a return line is a must. In pretty much every carby setup Ive seen (and I'm a V8 boy from way back) they use a high volume, low pressure pump which effectively cant pump any more into the carby when the float in the carby bowl shuts off a valve (kinda like a toilet cistern)
    yup yup, but some carby pumps can do maybe 10 or 12 psi, so they need to be dumbed down a bit... most of the cheaper pumps are quite happy to struggle nd just get the pressure you need
    either look up data for your pump, or stick pressure gauge on and see what happens!
  1. fuel system
    Last Post: 02-11-2007, 01:02 PM
  2. fuel setup
    Last Post: 12-09-2006, 09:24 AM
  3. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 09:14 PM
  4. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
