Results 1 to 15 of 17
Thread: Taller G series diff.
    Junior Member Grease Monkey Laurie D's Avatar
    Default Taller G series diff.
    Does anyone know of a taller (lower numerically) G series diff ratio than the 3.7 :1.
    If so, from what model? It must be for the G series 8", preferrably in the 3.3:1 to 3.5:1 range.
    Laurie D
    Default Re: Taller G series diff.
    Some later model hilux's came with 3.58 ratio's. Not exactly sure which one tho.
    Give these guys a call they should be able to help ya out. They looked after me with my 3.7 G series but had a 3.58 aswell and should be able to tell you which model had them.
    http://www.brisbaneautorecyclers.com.au/
    Thanks, that's a good start. Lower would be better though, I'll give them a call.
    Laurie D
    yeppo,
    Not sure you'll get much lower then 3.58 with toyota gears. If you have the center and carrier already just ebay "motive gears" they do a few lower ratio's for the G series and are $450 for the ring gear and pinion.
    That's what we're after, have lot's of carriers.
    Thanks!
    Laurie D
    Make sure the carrier was originally atleast as low as 4.3:1 IIRC
    The lower geared ratio carriers cannot be used with the taller gears. The pinion offset is different.
    Penrith BC
    though most aftermarket gears *should* be available to suit 'all' the crownwheel offset combinations
    you just need to know what youve got to startwith
    ../delete/ban
    tech moderator
    I have not seen the motive gear catologue so maybe your right
    I tried to fit a 3.7 gear set to a carrier that originally had 4.88 gears. No worky, unless you use a crown wheel spacer shim a few mm's thick = gay.
    AFAIK the group A Turbo MA70 came with a 3.23. No doubt they are a bit scarce though.
    Also have a talk to JustenGT8 as he has dealt with those sort of ratios. His old diff was as quoted below and has now changed it to a 3.42
    JZA70 TRD LSD diff (2.92:1)
    Thanks to all for your replies. A big help.
    Laurie D
    cambelt had one from some us tacoma. I think it was 3.23:1 from memory.
    QUICKEST 1JZ'S IN OZ
    The VG40 Century comes with a 3.2:1 G series, admittedly they're not exactly thick on the ground but it's another place to look.
    Junior Member Automotive Encyclopaedia Big rob's Avatar
    Looking for some clarification:
    Yes/no/depends: The G series pinion and crown wheel is compatible between the IRS and solid rear axle versions.
    Reason why I ask is I just had a 4 pinion LSD rebuilt for my soarer with the original 4.3 gearset, however at 60km/h its incredibly noisy. I was informed prior to the rebuild by the shop that due to some wear on the crown wheel this was a possibility but the couldn't be sure, so to rectify the problem I'm looking for a new gearset and the motive units are a good price from the states.
    So what gear sets from motive are compatible?
    Thanks,
    Rob
    most IRS ones need a 3mm spacer on the ring gear.. there are threads around somewhere..
    you measure the offset of the ring gear by placing a calliper on the ring gear flange to the centre of the axis where the one of the four pinnion gears sits
    hope that helps. if not dig up that thread its pretty thorough
  1. s series diff info needed
    By styler in forum Tech and Conversions
    Last Post: 04-12-2006, 02:40 PM
  2. RT132 Corona - T Series, diff noise?
    By bnicho in forum Tech and Conversions
    Last Post: 27-07-2006, 11:18 AM
