Results 1 to 5 of 5
Thread: Help with 1.5JZ problem
    Junior Member Grease Monkey gztwenty's Avatar
    May 2006
    Default Help with 1.5JZ problem
    Hi all. My mate has just finished his 1.5JZ conversion but has hit a problem.
    He has used an NA 2JZ, so has been required to tap in some oil feed holes for the turbo feeds. But there seems to be a problem with it no getting oil, as a result he thinks one of his turbos is now rooted (top mount KKK turbos).
    I've done about all I can over the phone with him (he's in Townsville, I'm now in Adelaide). Any ideas from the wise and knowledgeable on here? hehe
    1988 GZ20 Soarer GT + 1JZ-GTE
    Best ET: 12.57sec @ 111mph (full street trim)
    http://www.z20soarer.org/forums/showthread.php?t=162
    Junior Member Backyard Mechanic manny's Avatar
    Default Re: Help with 1.5JZ problem
    Where on the engine were the feeds tapped into?
    Has he measured oil flow and pressure from these feeds?
    With my old 1.5JZ setup which also used a 2JZ-GE block, the oil feed was tee'd off for the twins after the single supply was taken from the oil filter mount union bolt as described here http://www.mkiv.com/techarticles/oil...mod/index.html
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    May 2006
    As far as I'm aware, they drilled into the block, and tapped it in more-or-less the same spot a normal GTE engine. And no, don't think they measured it. And yeah, I've done the same kinda thing as you have on a mates 4AGZE with turbo. Got the oil feed from where the pressure sensor goes from memory (T-piece).
    Jun 2008
    There is no oil supplied to the galleries that he has used in a 2jzge block. As already mentioned, it need to be ran from the other side of the motor.
    Current Builds
    Soarer Built 1.5jz 425rwkws
    1JZ LPG Build, so far 204rwkw@10psi
    May 2006
    Ah I see. Cheers for that. That's pretty much what I thought would be the case. I shall forward that on and see how he goes.
  1. A340e Sluggish takeoff? Lockup Solenoid Problem?
    By Z2TT in forum Tech and Conversions
    Last Post: 13-01-2012, 05:10 PM
  2. 7mgte ideling problem and pressure problem
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 25-05-2008, 05:43 PM
  3. AE82 - Electric Problem
    By convert in forum Tech and Conversions
    Last Post: 24-02-2008, 11:30 PM
  4. Toymods Uploaded photos problem
    By JBs in forum Toymods Car Club Membership and Feedback
    Last Post: 26-11-2007, 03:18 AM
  5. CV joints problem with bigger engine (FWD)
    By progkamol in forum Tech and Conversions
    Last Post: 15-08-2006, 02:00 PM
