Got a boost gauge hooked up? Check to see that the charger is making positive pressure and that you dont have any intake leaks.
 4agze feels slow..
 4agze feels slow..
				hey all, just got 4a running now reliably, but feels fairly slow in the ta22..anyone here with this done converson to compare it too, does 0-100m hhits about 80km roughly
 Re: 4agze feels slow..
RA23 - Twincharged
JZZ20 - Daily
				making roughly 6psi, is this as fast as its meant to be?
				Check your cam timing, mine was "slow" when we first installed it, we'd stuffed up the cam timing, exhaust cam was 1 tooth out.
"Welcome the dude who ain't the buyer of mugs"
				its CAS and DLI, how do i check timing? or how is it adjusted??
				about 8psi is stock for the smallport DLI MAP 4AGZE.
To set timing, short pins E1 and Te1 in the diagnostic connector with a bit of wire, then run the engine and rotate the CAS until the timing reads 10deg with a timing light. Turn the car off and pull out the wire and you're good to go.
Incidentally, if you short the above pins and turn the car to on (without starting) you can read any error codes that may be in the ECU.
				Before you alter the timing with the CAS, confirm that your CAMS align with the marks on the backing plates when the crank is at the TDC mark on the oil pump housing (the mark is a little bump about 2mm in diameter).
