Results 1 to 3 of 3
Thread: 1JZ fuel rail w/ big injectors
    Junior Member 1st year Apprentice andyjz's Avatar
    Jan 2009
    Default 1JZ fuel rail w/ big injectors
    Hey all, just a quick question.
    Ive got a fairly significant fuel system in my z20 consisting of a Walbro pick up pump, 2x bosch 044, and 800cc sard injectors.
    I have been told that I should run a fuel feed line to each end of the standard fuel rail, and modify the center of the rail with a fitting to allow me to mount a fuel reg. Apparently this will prevent fuel starvation.
    Is this something that i should do??
    Regards,
    Andrew.
    Quote Originally Posted by TIMTAMS
    go the screamer!!!!! I just got one and I love it! Quiet when you want it and super loud when you wanna gate a bus stop!
    OLD JZZ20----> http://www.toymods.net/forums/showthread.php?t=50744
    I never though id do it... But ive got a 7m. 420.5rwkw@ 21psi
    Default Re: 1JZ fuel rail w/ big injectors
    its what i would do, and have been looking at if i go that direction...
    However, you can also get a fuel rail which will replace the stock one, look nicer, flow potentialy better, and only cost a couple of $$...
    jase
    JZA023
    Just re-read your post, i would have the fuel reg post fuel feed, obviously, and run the return line from the center**
    Just to clear that up for anyone else reading these posts...
    jase
    JZA023
  1. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  2. Replies: 1
