well from what i can see, advertised duration is 289deg intake, and 295deg exhaust, but most good cam shops will look at the 50 thou reading.
Advertised duration like you said can be at any lift the manufacturer specifies (usually they dont say), but most will supply a 50 thou reading as this is some what an industry standard. so when comparing cams try to look at the 50 thou reading. also your intake cam can be read as a 39/70 at 10 thou, and your exhaust as 42/73.
to read advertised duration look at the valve lash reading which gives 0.010", then go across to the chart and match up the lift, which will give you the duration.
valve lash is the gap between the cam and the shim. so make sure when you install the cam you run 0.010" valve lash,
