You need a tacho booster for the tacho to work...
Search tacho booster and ye will find:
http://www.toymods.net/forums/showthread.php?t=22574
http://www.toymods.net/forums/showthread.php?t=3710
As for the speedo, have you checked to see what tooth count your original gearbox had? It's ussually stamped on the gear... (suspect your original will be 6teeth to 22teeth [6:22] if your car was auto originally...might be 6:21...?)
JZZ30 auto should be 6:19 if I recall...
You can't swap the gears over? (Not the whole sensor...) I thought you could...
Another option is a jaycar speedo corrector...
e.g. http://www.jaycar.com.au/productView.asp?ID=KC5435
