I know that 7MGTE and 4AGZE coilpacks are compatible. I had a 7MGTE coilpack on an old GZE i worked on. Not sure about the 1GGZE.
Oh yeah, early 4AGZEs used single spark coilpacks with a dizzy, so you cant use those.
As Mulder said from the X-Files - I just want the truth....
I remember reading on the old forum that 7M-GTE, 4A-GZE and 1G-GZE coil packs are compatible....is this the case?
Or does it only apply to specific years / series?
Thanks,
Mitch.
RA23
1G-GZE
they might have different part numbers but are essentially the same part - 4agze (with DLI ignition not a dizzi) and 7mgte are definately the same.
1ggzi is probably the sam, the igniter works the same way as the 7mgte unit.
Thanks guys, this gives me a starting point - much appreciated.
RA23
1G-GZE
Yes, 1GGZe coil packs are also the same.![]()
