Results 1 to 10 of 10
Thread: Modified R154 ??
    Junior Member Grease Monkey zedrift's Avatar
    Dec 2006
    N.S.W.
    Default Modified R154 ??
    I bought this box a few months back and noticed a bit of the casing around the shifter had broken off but didnt think it would affect the operation.
    At closer inspection lately when cleaning i noticed that their have been some repairs or modifications done.Take a look at the weld..That cant be factory
    Any comments/opinions.
    Thanks,Gav
    Dec 2006
    N.S.W.
    Default Re: Modified R154 ??
    One more..
    Brisbane
    Most stuff we get here comes from accident damaged cars... it could be that it has been repaired after an accident.. or maybe used in a different car and needed to be lowered slightly or something.
    If the box works, pretend it didn't happen
    That bolt also doesn't look factory
    Wilbo's JZA80
    Wilbo's JZZ12
    Would i be correct in saying a dust seal should go where it has broken off around the lip?
    vic
    probably been dropped at some stage, and broken the end of.. then someones tried to 'fix' it
    Forum Sponsor Conversion King
    Dec 2006
    Ummm,
    How bout a DIY short shifter?
    that extended ball section is what is commonly done to reduce throw while still having a tall stick.
    Or are you asking about the repair on the shift rod? need to circle the weld you are talking about as i can see 3 in the pics.
    Linden
    Dec 2006
    N.S.W.
    Yeah the bolts are definately not factory and there should be a dust boot on the section where the damage is,i will put on on when it goes in the car.
    The weld im talking about is just in front of the damage on the shifting rod that goes into the box on the 2nd pic.
    With the damage to the casing i figured it must be a repair but also thought that if it was a little shorter due to the repair/mod it may have effectively given me a short shifter,but i would have thought that would be all about pivot points.
    Gav
    Is awesome Backyard Mechanic
    Jan 2008
    hey Gav,
    I see what they have done! it is exactly how I did to mine R154 when I did the conversion.
    They've shorten the remote shifter linkage, and move the shifter position foward. But when you put in reverse gear or 2nd gear, it wont go in all the way because it will hit the bolt (on the 2nd picture), that is why they grinded it down.
    The only issue you might have is cant be able to put the plastic dust cover on but cable tie will works.
    Jan 2008
    That rod, originally longer. It was cutted and welded to match the length with the remote shifter.
  1. r154 shifting experiences
    Last Post: 24-11-2009, 09:47 PM
  2. R154 rear mount vs ms75 crown
    By mr75 in forum Tech and Conversions
    Last Post: 07-08-2009, 06:25 AM
  3. R154? Good or no good?
    By TTV8RA23 in forum Tech and Conversions
    Last Post: 12-02-2008, 09:18 AM
  4. R154 Rebuild Questions
    By delazy in forum Tech and Conversions
    Last Post: 22-08-2007, 06:14 PM
