Here is my sheet to start off.
It can be seen from the A/F ratios it has never been tuned properly.
From my Mild 2T that was in my Three Tone Green TA-22
Engine:
1mm O/S Toyota 9.8 pistons
Stock rods
Stock crank
Ligtened OEM flywheel 6.6Kg
Stock clutch
All balanced
Mild cam, used to be called a 3/4 race cam back in the eighties (30/70 but cannot recall exact)
Head:
Std sized valves
Mild porting
Shaved to give 10.5:1 compression ratio.
Double valve springs (unknown inners, OEM outers)
4 into 1 extractors 2.25 inch exhaust
Mikuni/TRD sidedraught manifold
Dual 44mm Mikuni PHH carbies
Main Air jet #160
Main jet #145
Pilot jet #60
Outer Venturi #34
Standard points but recuved distributor with vacuum advance removed.
Runs on standard Un-leaded fuel.
Regards
Rodger
