Results 1 to 3 of 3
Thread: Ls400 Engine problem
    Junior Member 1st year Apprentice slipway NZ's Avatar
    Apr 2007
    Brisbane, QLD
    Default Ls400 Engine problem
    Happened the other day, engine loses all guts at full throttle, feels like running out of gas,
    Part throttle runs fine, as soon as you stab it engine revs increase to about 3k then drops tp 1.5k and sits there reving from 1- 1.5k up and down.
    I did the fault coses on diagnostics and its came up 41, i looked that up and it said tps prob so swapped that and still same problem.
    Them problem will happen most of the time and then seems to clear for abit, any ideas guys?
    abit of a shitty explanation but hope you get it
    User Conversion King
    NWA
    Default Re: Ls400 Engine problem
    sounds like the IDL circuit is staying closed on the TPS
    if it happens again then disconnect the TPS altogether and see what happens.
    it will probably make the ECU have a cry about no TPS signal but it should stop the revving problem.
    hello
    Mar 2009
    If you haven't done so already, you should try disconnecting the battery for a few minutes. This should reset the computer. Not sure if this will work or not but it doesn't hurt to try.
  1. 4age 20v Silvertop - Check engine light?
    By Macross in forum Tech and Conversions
    Last Post: 29-09-2010, 08:45 AM
  2. MA70 --> JZA70 Conversion
  3. CV joints problem with bigger engine (FWD)
    By progkamol in forum Tech and Conversions
    Last Post: 15-08-2006, 02:00 PM
  4. Earthing kits - myths or truths? (modem size warning)
    By Mos in forum Tech and Conversions
    Last Post: 31-05-2006, 12:38 PM
