Results 1 to 4 of 4
Thread: 1ggte throttle signal wire
    Oct 2008
    Auckland
    Default 1ggte throttle signal wire
    Im hooking up an safc2 to my ga70 supra and I need to know if there is a throttle sensor input as I cannot find one. any help would be appreciated.
    Default Re: 1ggte throttle signal wire
    Just looking at the 1G schematic now, and the only thing I can see that might be relevant is the TPS.. theres 4 wires, 3 of which don't seem to be relevant, which leaves me with pin 11 (GEN III) which is labeld VTA, but I don't know what that means, Someone might be able to shed more light on the matter?
    Schematic is in this thread: http://www.toymods.net/forums/showthread.php?t=15461
    '77 RA28LT #2 ← 2.2L 18RG...
    I wired mine to the TPS, worked fine, just remember to tell the safc that its a flapper style AFM before you start it up. The wiring diagrams that come with teh safc will tell you what pin to piggy back.
    RA23 - Twincharged
    JZZ20 - Daily
    Oct 2008
    Auckland
    yeah thanks the 1g in my car dosent have a vta wire hence the problem. Kedderz could you tell me which wire you tapped into for the tps? safc wiring diagram says that there is no throttle signal wire.
  1. 3tgteu on Mega squirt?
    By 3jcelica in forum Tech and Conversions
    Last Post: 09-03-2008, 11:23 PM
  2. Error code - "Load signal circuit" help needed (4Y-E)
    Last Post: 10-02-2008, 02:23 AM
  3. How do you wire a light to signal thermo fans are on?
    By pisso001 in forum Tech and Conversions
    Last Post: 18-08-2007, 07:56 PM
  4. Quad throttle injector options
    By jezza323 in forum Tech and Conversions
    Last Post: 26-07-2007, 06:32 PM
