if the oil pressure sensor is unpluged it wont start with the key but can be roll started doesnt explain the cutting out but somthing to have a look at
Hi guys, anyone come across this.
Drivingalong the car seems to go into decellerate mode and cuts out failing to restart unless it is roll started. have tried ecu, injectors, fuel pump and pressure reg,
any other suggestions, also if i push the throttle to the floor whilst it is cutting out it picks up and keeps going. have had an auto electrician check over the loom aswell and all looked and tested ok.
cheers Brad
1985 RT142, 1GGTE,.now with t67-25g
2009 Ford Fiesta LX
1970 Ford Cortina MK2 440
cheers will have a look at it
2009 Ford Fiesta LX
Stock ECU? Got diagnostics?
RA23 - Twincharged
JZZ20 - Daily
So you've checked the loom running in front of the engine? On my 1G the plastic bracket holding that loom broke and the wires began to occasionally short on a pulley which made the engine cut out etc.
