takes me 4 - 5 hours from start to go working alone
pretty hard job if it's your first time though...
1. raise car onto jack stands
2. remove wheels
3. crack CV carrier nuts
4. Unbolt rear E-W crossmember
5. unbolt ball joint from lower control arm, swing hub out and remove cv from hub
6. drain gearbox oil
7. pop CV's out of the box on the passenger side - on the drivers side release the circlip on the carrier and it will simply slide out
8. remove shifter cables - 2 parts to this
8.1 remove the circlip that connects them to the actuators
8.2 remove the C clips that hold them to the gearbox
9. Disconnect the speedo drive
10. unbolt the clutch slave cylinder and lines that hold it to gearbox - hang it somewhere in the bay
11. disconnect reverse sensor plug
12. disconnect battery
13. disconnect and unbolt starter motor
14. support the sump of the engine with a block of wood and a jack
15. unbolt N-S engine mounts from crossmember, unbolt N-S crossmember and move it out of the way
16. go around the bellhousing and remove all the bolts
17. support gearbox with a second jack
18. unbolt passenger side gearbox mount
19. gearbox should now come out
20. remove clutch
and do it all again in reverse
