Results 1 to 3 of 3
Thread: Replacing gen1 3SGE clutch (How Hard?)
    Feb 2009
    Default Replacing gen1 3SGE clutch (How Hard?)
    Hi Guyz,
    I was just wondering how hard it is to replace a stock gen1 3SGE's clutch? I know its fwd and I know its an east west engine, so what is involved in changing the clutch?
    Is there a tutorial anywhere from which I may seek guidance from?
    Thanx Heaps Guys
    Default Re: Replacing gen1 3SGE clutch (How Hard?)
    takes me 4 - 5 hours from start to go working alone
    pretty hard job if it's your first time though...
    1. raise car onto jack stands
    2. remove wheels
    3. crack CV carrier nuts
    4. Unbolt rear E-W crossmember
    5. unbolt ball joint from lower control arm, swing hub out and remove cv from hub
    6. drain gearbox oil
    7. pop CV's out of the box on the passenger side - on the drivers side release the circlip on the carrier and it will simply slide out
    8. remove shifter cables - 2 parts to this
    8.1 remove the circlip that connects them to the actuators
    8.2 remove the C clips that hold them to the gearbox
    9. Disconnect the speedo drive
    10. unbolt the clutch slave cylinder and lines that hold it to gearbox - hang it somewhere in the bay
    11. disconnect reverse sensor plug
    12. disconnect battery
    13. disconnect and unbolt starter motor
    14. support the sump of the engine with a block of wood and a jack
    15. unbolt N-S engine mounts from crossmember, unbolt N-S crossmember and move it out of the way
    16. go around the bellhousing and remove all the bolts
    17. support gearbox with a second jack
    18. unbolt passenger side gearbox mount
    19. gearbox should now come out
    20. remove clutch
    and do it all again in reverse
    I am the sun
    Samet - you've asked a heap of questions on here, nothing wrong with that but all of this has been covered befoire in tech section and in the st162 dedicated thread. I suggest you do a search first and also go down to your local autobarn, repco etc and get a haynes workshop manual. Invaluable for working on the 162.
    PS - congrats on getting into a 162. If its your first car, keep the motor stock other than extractors, exhaust and filter, mess with the timing and put your dollars into redoing all of the suspensions, bushes, brakes and tyres as they are no doubt the original items
  1. What is involved in turbocharging a Gen1 3SGE?
    By samet in forum Tech and Conversions
    Last Post: 28-08-2009, 09:23 PM
  2. Grease on flywheel / rear clutch surface..wtf!
    Last Post: 27-03-2006, 01:14 PM
  3. Simple 3sge Mods
    By Lonewolf in forum Tech and Conversions
    Last Post: 18-02-2006, 02:47 PM
