If you do a search on the net about cam timing you will find a heap of information. Here is just one:
http://www.rbracing-rsr.com/camshaft.html
I recommend you degree your cams.
I would have them at 106* lobe separation angle for mid to top end. You can go bigger or smaller it's up to you. I wouldn't expect too much from a standard cam because it's duration was probably meant for emissions control.
Here is an example of a setting:
intake center line 104* (4 degrees advanced)
exhaust center line 108*
104 + 108 = 212
212 \ 2 = 106 lsa
When you degree your cams at least you can find out:
- advertised duration (in/ex)
- 0.050" duration (in/ex)
- max lift (in/ex)
- lift at TDC (in/ex)
- max lift before the valve hits the piston at TDC.
If you want bottom end go for something like 112 lsa, if you want top end go for 100 lsa. So anything in between would be for mid range. You can have the intake cam advanced or equal to the exhaust cam it just depends if your motor likes it.
cheers.
