Unlikely. You could always pull your one out and compare.
I presume you're talking about the air suspension? If the air bag has a puncture then it can be repaired - chat to any air suspension specialist.
just so everyone knows, YES i have searched this forum, many other forums and google and i can't read japanese so i'm gona ask here.
does anyone know if the rear struts out of a soarer may possibly fit in my uzs131 crown? cause the back won't go up anymore and it needs to be fixed.
yeah its the air suspension,
what if the pump isn't making any sound either? screwed even more?
p.s. they should make a noise right?![]()
Not really sure to be honest, but if the pump has failed then it might be an easy proposition to buy a pump from a front cut.
I haven't had a good look at a 130 series - is there an air tank in the rear for those things? Is it leaking? Checked all the fuses?
yeah there is an air tank in the rear, i havent checked any fuses yet though.
also there was a coilover kit i saw on the net that you can get for the celsior (ls400), i'm guessing i cant use these kits for my car?
