Results 31 to 45 of 51
Thread: Various Brake Caliper Dimensions 56K warning
    Default Re: Various Brake Caliper Dimensions 56K warning
    Quote Originally Posted by clubagreenie
    Cool1's are probably broken...
    heh heh
    i'm hoping to have some R33 GTS calipers soon to measure...
    i think they are mostly the same as the Z32 except for the size of the attachign arms
    south australia
    yes i have them here and the measurements...i am just waiting on my pictures
    guys, can we start getting meights and measurements of single and twin pots also??
    like spoontah, MA61, ST185, St202..... to compare the weights with the 4 potters etc?
    pretty please
    hold ur panties OC, i'll get the st202 ones done soon
    south australia
    r33 front calipers added to front page now.
    very similar to z32 caliper in many dimensions (as expected)
    *note all measurements done with tape measure (need to buy verniers one day ) so give or take 1mm here or there. i have tried to make them as accurate as possible, but using a tape measure and having a cast on one hand makes it a lil more difficult
    Celica ST205 caliper:
    Weight: 5KG with two pads
    Material: Alloy
    Pistons: Four
    Piston Diameter : 35mm each
    Celica ST202 Caliper
    Weight: 6.5Kg with two pads
    Material: Cast Iron
    Pistons: Two
    Piston Diameter: 37mm (piston top) actual piston is 40.5mm. both pistons are the same
    Caliper Comparison
    tasmania
    i'll get some pics/measurements of the corona twin opposed-pot calipers, and the 4runner 4-pot calipers(solid disc) soon.
    nobody's been putting the offset of the calipers in their measurements. i mean mounting surface to disc centre.
    great work guys.
    beer me!
  8. #38
    south australia
    in r33/z32, the mounting surface face to the gap that the rotor goes in is flush
    therefore the distance can be derived from half the gap the rotor fits in...if that makes sense.
    rx7 has the measurement between where the mounting surface and where the gapstarts for the rotor so again you can derive the measurement to the centreline of the rotor.
    although i will chuck the thickness of the mounting lug on the r33 one...22.5mm in case you wanted to know sooner (z32 probably the same).Rx7 already has the lug thickness
  9. #39
    Toymods Club Member #274 Backyard Mechanic Rallystanza's Avatar
    Can anyone supply me with all the pics and corresponding dimensions for the R32/Z32 rear twin spot calipers?
    Thanks guys.
    Jez
  10. #40
    How does one get hold of those ST202 calipers?
    Are they on something here in Australia or are they one of those in between models.
    After St162s I get lost with numbers.
    Regards
    Rodger
  11. #41
    ST202 is a japanese model of the local ST204 celica (the four round lights version celica).
    the brakes themselves i obtained off a friend who had a half cut in, however there was another person on this forum who had a pair, though he didnt say where he got them exactly.
    you could try asking some japanese importers if they have the brakes in, or a half cut from a st202 that has the same brakes. just check that the brake part number is the same to be sure. these brakes also came standard on one of the caldina GT's in Japan. have a read of this thread too,
    http://toymods.net/forums/showthread...ighlight=st202
    Thanks da_horse,
    These twin spot ST-202 ones may be a direct swap for a Magna single spot caliper I use on a couple of my brake set ups. I must now measure the magna ones.
    Regards
    Rodger
  13. #43
    Question Re: Various Brake Caliper Dimensions 56K warning
    To cut to the chase, does anyone know if any of these calipers work as replacements for the TA22 calipers? Or are these mainly those with RA23/28 struts doing the brake upgrades for them?
  14. #44
    south australia
    neither or all
    they are dimensions of calipers to get an idea on spacing and brackets required to get them to fit to whatever strut/mounting system is in your car, also what the clearances are to rims and whatnot.
    For instance the bolt spacing on the nissan calipers is the same as the bolt spacing for the brackets on the ra60 so spacers are all that is required to get the bracket to fit.
    the bolt spacing for mounting calipers in an ra28/3/40 is diffent so a suitable bracket to accomodate for the calipers is required.
    It is simply a visual representation guide to see what would be required to fit to the car and also what clearances would be like.
  15. #45
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Quote Originally Posted by barned01
    Anyone else that has any common calipers...it would be good to get a reasonable comparison together.
    standard celica
    standard ae86
    ma70
    hilux (the hilux conversion caliper...)
    commodore vt
    etc...
    I have a Toyota Hi lux four spot in a 280ZX front qed.
    But what I would like to see is how to fit the Avante discs to a Corona drum rear without the trouble and make sure the handbrake works.
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    By The Witzl in forum FAQ
  2. putting a spacer in a caliper to allow a thicker disc. wise?
    Last Post: 13-03-2006, 02:40 PM
  3. BA Falcon Brake Disc dimensions
    By CrUZida in forum Tech and Conversions
    Last Post: 23-01-2006, 08:08 PM
  4. Brake caliper question
    By smitty1 in forum Tech and Conversions
    Last Post: 09-01-2006, 05:29 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
