Page 1 of 4 123 ... LastLast
Results 1 to 15 of 51
Thread: Various Brake Caliper Dimensions 56K warning
    south australia
    Default Various Brake Caliper Dimensions 56K warning
    RX7 front Brake caliper (suit 22mm rotor)
    4 Piston Caliper
    Piston Diameter 32mm
    weight: 2.6kg (bare)
    south australia
    Default Re: Various Brake Caliper Dimensions
    Z32 Front Alloy Caliper (suit 30MM rotor) (Courtesy of OldCorollas)
    4 piston Caliper
    Piston diameter(s):
    Weight: 3.6kg
    south australia
    R33 Front caliper (turbo suit 296x30mm disc)
    4 piston
    piston diameter:37mm
    caliper weight: 3.8kg
    south australia
    Anyone else that has any common calipers...it would be good to get a reasonable comparison together.
    standard celica
    standard ae86
    ma70
    hilux (the hilux conversion caliper...)
    commodore vt
    etc...
    ill do the RA60 celica when i find some micrometers
    85 TA63 Carina 3sge
    89 GZ20 Snoarer 1jz
    Default Re: Various Brake Caliper Dimensions 56K warning
    Thanks man, this is a great reference. +rep for you.
    I like this.
    Good job. These are just the dimensions I ask for when these calipers come up for sale.
    Anyone got the Hilux dimensions, the one that is recommended for the Pugeot rotor conversion?
    I can supply 80 Series Landcruiser for comparison.
    Regards
    Rodger
    80 Series Landcruiser and Hilux should be exactly the same. Only i think one has a nodule on the front which sits out slightly.
    I have some Hilux calipers, but they are currently fitted and as such would be slightly difficult to measure. However, i am soon to be upgrading them to Mazda alloy 4spots and will measure them up then if no-one has done so before.
    Takai,
    If that is the case, I'll confirm when I measure, then the Hilux/Pugeot rotor conversion makes for a damn heavy combination.
    I got a very cheap set of Lancrusier calipers and started to fit them up to some RA23 struts/hubs with a rotor I'd selected and gave up as the weight of the caliper was rediculous compared to the gain in brake performance (if any) over an RA65 caliper on the same disc. All into a TA-22.
    Interesting to find out the weight of the Hilux caliper then.
    Regards
    Rodger
    My Hilux calipers weigh in at just over 6kg each. According to Australia Post that is. Had a pair sent to me and the box all up was 12.5kg with extremely little weight in the packing (potato bubble things).
    will do ra28 calipers tomorow.. spare pair in the shed
    Black Betty >HERE!<
    (\__/)
    Quote Originally Posted by Rodger
    Takai,
    Regards
    Rodger
    I've got a set of Porshe Boxster calipers... pricey compared to Z, RX and GTR, but costing just a little over $1250 new for a full kit to fit an Audi, They were a bargin compared to the brembo labled and half the weight... two peice design, so just find a good turner/machinist, and will fit over a 22mm thick disc. Will post pics.
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    200sx callipers look to be very close to the hilux callipers except for being alloy so heaps lighter
    south australia
    i thought 200sx were cast iron?
    chuck one on a scale and see what it comes up.
    this is a late model 200sx that i am thinking of.
    Tasmania
    srry i don't have 1 to put on scales
    By The Witzl in forum FAQ
  2. putting a spacer in a caliper to allow a thicker disc. wise?
    Last Post: 13-03-2006, 02:40 PM
  3. BA Falcon Brake Disc dimensions
    By CrUZida in forum Tech and Conversions
    Last Post: 23-01-2006, 08:08 PM
  4. Brake caliper question
    By smitty1 in forum Tech and Conversions
    Last Post: 09-01-2006, 05:29 PM
  5. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
