Results 1 to 3 of 3
Thread: 1600s Corona dash wiring.
    Basher Grease Monkey
    Feb 2007
    Default 1600s Corona dash wiring.
    Need help with a wiring diagram for a 66 1600s corona and a rt40 as am fitting the sports dash but the plugs are different.
    could any one out there possibly make me a copy.
    Cheers Scott
    coronacoronacoronacorona
    Tasmania
    Default Re: 1600s Corona dash wiring.
    Been along time since I did this but will see how I go.
    If you have all the necessary wiring on the S dash then it should be a breeze.
    Look for the large factory plug on the back of the original dash and cut that off.
    As the S dash runs individual guages it will be easy to just check the wiring on these and match the colour codes to the original plug.
    If you cut the original plug off leave enuff wiring if you need to re attach the original dash plus you can even put the original plug back on the dash and trace on the back of the printed circuit board to know what colour wiring goes to what.
    As to the Tacho if you post the wiring colours coming out of this I will be able to tell you where that needs to be hooked up as the standard Ronas never had this option.
    And no there isn't a wiring diagram for a 1600S Rona.
    You will also need to change the oil sender switch also.
    Cheers Brett.
    Feb 2007
    thanks for the reply,I should be able to work it all out from that,including tacho
    Cheers Scott
  1. TA22 Wiring Harness (problem) Difference
    By raj2t in forum Tech and Conversions
    Last Post: 10-03-2009, 09:12 PM
  2. 1jzgte into 88hilux, jzz30 wiring help????
    By hu5tln in forum Tech and Conversions
    Last Post: 28-01-2009, 07:13 PM
  3. 20v blacktop vvt wiring + alt wiring
    By cooter in forum Tech and Conversions
    Last Post: 20-04-2007, 10:37 PM
  4. Wiring Experts! Seperating looms for engine swaps?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 29-08-2006, 06:29 PM
