Results 1 to 3 of 3
Thread: Adjusting cams
    Default Adjusting cams
    Is it possible to adjust cam timing with standard cams in a 3SGE ?
    1989 st162 White Lightening
    purs like a ....
    Default Re: Adjusting cams
    Yeah, but only by removing the cam belt. = pain in the butt.
    I read on the forum that 3SGTE adjustable cam gears fit, try searching for that possibly? I dont think there's much gain to be had unless you've got aftermarket cams though.
    I'm confused a little.
    Do you have adjustable cam wheels? cause if not then you would only be able to adjust by the teeth and belt which would give you something likr 10deg per tooth which would be shit and give you 0 benefits and more likely give you lots of downsides.
    In short you could but you would recieve no gains
    - LeeRoy
  1. 272deg Cams, Bigport GE, Stock Comp...Big Improvement!
    By craigy in forum Tech and Conversions
    Last Post: 07-04-2006, 03:00 PM
  2. 2jz-ge cams
    Last Post: 16-03-2006, 03:56 PM
  3. 2jzgte cams in 1jzgte do they fit without mod
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 12-01-2006, 08:54 AM
