old dellows or new?
how much power are you making again?
hey peeps, its clutch time as my single plate is poo. Extreme tell me that they cant supply a better single plate but can do me a twin carbon clutch.
Has anyone tried one of these bad boys, what are they like ?. The good thing about them is that they can custom build it to fit in my bellhousing, unlike other off shelf one's.
open to ideas ?
4ag-dellows-w58 is what im working with.
thanx.
i dont know if its the old or new (any way to tell? ) i bought it 2nd hand.
making 315hp but got more boost and rpm for it so should see a bit more, maybe 360-70 odd.
i have a 215mm in it now but it needed a bit of modding.
geez cuzzo, i thought you were onto something
you built me up for the answer i didnt get haha.
thanx man, but been there mynes not 1600kg tho its 1350kg. I didnt think they did a 1600 even 1350 was a stretch they rekon.
Hmm maybe i made that part up. i guess mine is 1350 too then.
Is urs slipping?
Twin plate is your next option as you noted. Removes the street application though.
Why are you upgrading?
yeh it slippsits hasnt done that many k's either. twins can be pretty forgiving but ive never tried or driven an extreme twin before nor do i know anyone that has one.
i need to upgrade asap but its gonna be an expensive stint because i need to rebuild the box aswell.
i tried to give you rep but apparantly i have to give it to other people first(i do rememeber having a winge about that haha)
Not true these days, the multi plate carbon units are more friendly in most cases than button single plates. Not sure what RP071 on here is using in terms of brand but it's a multi plate carbon unit behind a 2J and he uses it as a daily. Others who have driven it thought it was unreal too.
You're right on the 1350 clamp load being about the limit on the 4A single plates too, everyone seems say around 1300kg is about as much as they can get out of these particular pressure plates in the 212mm version.
If you go the mutliplate be sure to let us know how it goes.
My KE25 thread
NPC clutches have done a few 4age clutches, I myself have a "frankenstein" clutch in my 4agte levin(ae92 fwd). Nick was a good bloke to talk with, clutch is beautiful to drive on(I had a twin, was super ghey).
Clutch mainly comprises of a modified evo pressureplate with a custom flywheel to suit, clamp was around the 1350kg mark but he said he could go higher. (215mm)
Oh cushioned button also.
Was fairly well priced as well.
Might be worth a shot, P.S he has done them for sprinter applications also![]()
As said, twin plates can be plenty streetable!
sorry cuzzo, last night i read that as when are you upgrading not why haha. (but yeh it slipps)
yeh YLD ill prolly go with the multi tho ill give NPC a call (thanx PURE) but ill let you know how it goes, it would be good to get a nice clutch in the dellows bellhousing and lay some rubber on the ground
ive been driving the car heaps latley but i dont normaly so even if its a bit of a prick to drive i wont mind. (tho im confident it will fine)
thanx fellaz.
