Page 1 of 10 123 ... LastLast
Results 1 to 15 of 139
Thread: Turbo Preference for 4age
    ......................... Carport Converter
    Default Turbo Preference for 4age
    Hey Guys, i searched this forum and the old but couldn't find out much on which turbo would be better.
    I am going turbo with my 4age 16v Ke25. I plan to leave block standard for now and just run low boost. Nothing ridiculous... I was thinking about either going the t25 small ca18 trubo or go the Rb20 Turbo(forgot the model). I have heard that a rb20 turbo flows better, but not sure which to chose. I have been offered a rb20 turbo in excellent order for a good price, but not sure,. Does anyone have any advice on which one would be better for my application??
    Michael
    Default Re: Turbo Preference for 4age
    i run a t25 from a ca18det and recomend it for your 4age. i use a stock 4age, but cheated and used a 1mm metal headgasket (off my old 4agze) combined with a cheap compisite headgasket to lower my c/r as i use a 4agze ECU and electronics etc. and cannot tune it. if i had tuneable aftermarket engine management i would of left the engine 9.4:1 c/r.
    i run 12psi when ever i'm in it, the t25 on mine spools @ ~2700rpm and full boost by ~4000rpm til redline. keeping the c/r higher might help spool up a little earlier, not to mention should have more torque and better fuel economy.
    what engine management are you going to use?
    no need for a Domestic Engineer finney's Avatar
    well i know of a certain 4AGTE that has put out 169fwkw with a td04.... but then again a good manifold will also produce good figures. i believe yellorolla was responsible for this particular manifold.. but then again if i'm wrong feel free to correct me as i've had a fair bit to drink today
    4AGTE SX - '4AGE' - 13.6 @ 103mph - 163fwkw @ 18psi - SOLD
    1998 JZX100 Tourer V - SOLD and now lives in radelaide
    1992 GTI - SOLD
    pedro sanchez wannabee Domestic Engineer Dom-AE71's Avatar
    Mike!
    Your better off using a T25g off a early model SR20 as apposed to the CA18 due to the fact the CA18 T25 is ceramic and the SR20 T25g is steel turbine.
    My mate with his swift has a T25g bolted onto it and it starts spooling up VERY early.
    P.S word on the street is theres a motor in your garage with a T25g already bolted onto it
    a log style manifold is capable of producing ~350hp (depending on the other stuff bolted on as well), so you dont 'really' need anything fancy. different styles of manifold can effect spool up of the turbo.
    CA18 T25 is ceramic
    hrrmm.. i'm sure both my ca18det t25's are steel wheeled.
    what a/r's are the t25g?
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    I've got a T25G-size turbo sitting around that would probably be better than anything mentioned so far. It's brand new, and is yours for $700 if you want it.
    PM me for details if you're interested.
    Jeremy.
    sa
    Say you wanted a turbo that'd spool at about 3500-4000 rpm and provide a solid 25psi to redline, what would you use?
    Okcheers for the advice guys. At the moment i am just working out things for the project. Anyone else have anything to say?
    Michael
    Junior Member Carport Converter 4agte's Avatar
    Quote Originally Posted by myne
    a gt 2535 or 2540
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    yeah mate the T25 seems to be the go, or if you have the money you can the the ball bearing GT25. BTW your old sprinter is going through a fair transformation in my workshop as we speak
    ethanol sniffing Backyard Mechanic adamaw11's Avatar
    Quote Originally Posted by feral4mr2
    Any idea of how much that would have dropped the compression by?
    thats probably a good simple solution in many cases.
    you can work it out 'fairly' simply, (trusty engineering) i think it readuces it to around the high 8's (guess)
    sa
    How do you think a T28 would respond on a 4age?
    Anyone done it?
    Pro's and cons of it?
    4SAKEN-So my old sprinter is still around?? Hows it looking? If you got any pics it would be much appreciated!
    Yeah i am starting to go towards t25g. but we'll see wat happens
    Michael
    Also i will be only looking for around 7psi for now, then when a solid block gets built i will upgrade turbo.
    Michael
  1. **HELP** Twin turbo to single 1jz setup.
    Last Post: 11-07-2011, 11:06 AM
  2. 2jz-gte Turbo Oil Feeds
    By dori dori in forum Tech and Conversions
    Last Post: 05-01-2006, 10:26 AM
  3. 5mge turbo
    By pete05 in forum Tech and Conversions
    Last Post: 18-12-2005, 07:23 PM
