This all started when after overheating I noticed that its blowing white smoke and idling really low, so I assumed that time after researching and asking people. No visible milky residue on the cap or oil dipstick or even in the radiator that water and oil are mixing together.
Upon opening the head we noticed the "milky" residue but not that much. The head taken to a engine rebuilder/head machining to get checked and it was machined then cleaned.
We didnt check the block if its cracked or not. I've read that its not very common for a 3VZFE to crack a block unless you've been driving the car for a very long period with it overheating.
Everything was put back again, and the mechanic suggested that we can re-use the head bolts even though I suggested that its supposed to be replaced every time you take it off. The mechanic inspected the bolts and told me that they are fine to re-use.
the mechanic hasnt changed the oil yet as to test if there's any coolant leaking...
The old gasket didnt look too bad not sure where it blew though I think its between #6 cylinder, I'll check with the mechanic.
Right now the temp needle is just sitting right on the middle. The mechanic hasnt check for exhaust gas in coolant, thats the next step now.
