Results 1 to 3 of 3
Thread: turbine housing survey
    -Street Drag Machine- Grease Monkey renxun's Avatar
    Jan 2007
    Sabah
    Default turbine housing survey
    what size of turbine housing you guys using?
    do state down some info as below as well..
    engine : 1jz-gte
    Turbo : t04z.
    turbine housing : a/r 0.7 t4
    cam : 256/256
    would like to try the a/r84 t4 but a bit wory about the boost thereshold. exhaust restriction isnt an issue as im using side pipe that dump just below my door
    Drift Drift Drift and drift untill getting high fever...
    Default Re: turbine housing survey
    engine : 1jz-gte
    Turbo : hypergear tr44 57mm inducer
    turbine housing : a/r 0.63 t3
    cam : stock
    engine : 1jz-gte
    Turbo : gt3076R 57mm inducer
    turbine housing : a/r 0.82 t3
    cam : stock
    QUICKEST 1JZ'S IN OZ
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    engine: 1jzgte
    turbo: gt35r .7 A/R
    rear housing .83
    standard cams
    87' z20 Soarer - 1jz Gt35r -
  1. Turbos 101
  2. Removing turbo turbine housing
    By BlackSupra in forum Tech and Conversions
    Last Post: 02-01-2006, 11:33 AM
