I can't comment on the effective difference, however I can offer an alternative. As others have already stated, any transition between diameters (especially over short distances) is going to lead to flow separation and contribute to boundary layer effects.
This can also be caused by transitions between two adjacent pipes such as connecting your intake pipe to the turbo inlet with a silicone joiner. The connection will have two sharp edges disturbing flow.
An alternative to your suggestions would be a long taper at 7 degrees or so between the turbo inlet and and filter with smooth long radius transitions where the pipe is constant diameter for clamping.
Otherwise a bellmouth on the turbo with a large diameter pipe, significantly larger than the turbocharger inlet to act as a plenum. This option would have no physical connection to the bellmouth itself.
