Results 1 to 3 of 3
Thread: Easy 4AGE/AW11 Related Questions
    Gearwhore. Backyard Mechanic
    Oct 2008
    Default Easy 4AGE/AW11 Related Questions
    All questions are about an early bigport (3 rib, AFM) AW11.
    1. I've removed EGR. Manifold is blocked off, new extractors are on the car. Is it going to throw any sort of ECU errors or run like a dog?
    2. I've removed air con (all lines, compressor, brackets, etc). I've bridged a sensor in the front of the car, the thermo fans no longer come on when ignition is on. Is this all I have to do for the car to run properly?
    3. Was my car the only one to come with a factory oil-water cooler? I don't remember seeing a cooler on other FWD 4AGE setups. No real reason I'm asking, just curious.
    4. How am I going to implement a remote filter/aftermarket oil cooler? I was thinking to ditch all the factory stuff, remove the factory sandwich plate, run a universal relocator kit, mount the cooler where the air comes in behind the drivers door and run a large pull-type fan behind the cooler. If you know of any better setups, let me know.
    Victoria, Mt Macedon
    Default Re: Easy 4AGE/AW11 Related Questions
    3 - FWD 4AGEs (some?? all??) came with bypass oil coolers too. An adaptor block with a thermostat that bypassed some oil to the cooler then the sump when above temp.
    4 - Unless the filter is really hard to get to now (or there's some other reason to move it), I'd consider leaving the filter in place and just installing a remote cooler.
    Hen
    Oct 2008
    I'm moving the filter because it's a pain in the arse to get to (not looking forward to lifting the car up without a hoist whenever I want to change it), I want a bit more room for big primary pipes for extractors when the supercharger goes on and if I'm doing a cooler without remote setup I will need a sandwich plate, meaning less room at the back of the block.
    Cheers.
  1. total newbie questions!!
    By rollsy in forum Tech and Conversions
    Last Post: 23-07-2006, 07:28 PM
  2. bolting bits back together AKA engine rebuild questions
    By love ke70 in forum Tech and Conversions
    Last Post: 16-07-2006, 06:08 PM
  3. AE82 GZE questions
    By gbanger in forum Tech and Conversions
    Last Post: 07-07-2006, 02:27 PM
  4. Aftermarket Engine Management - Burning Questions
    Last Post: 01-07-2006, 06:30 AM
